keeks707 Posted August 19, 2011 Report Share Posted August 19, 2011 i just looked up that you could mod the shift star.. never seen or heard about it. what are the pros and cons of this mod? Thanks Quote Link to comment Share on other sites More sharing options...
tedd1 Posted August 19, 2011 Report Share Posted August 19, 2011 Pros= smoother, easier. more positive shifts. Cons= None http://bansheehq.com...121574&view= http://bansheehq.com...120410&view= http://bansheehq.com...topic=126900 I stole this pic from Savage420... Quote Link to comment Share on other sites More sharing options...
06specialedition Posted August 19, 2011 Report Share Posted August 19, 2011 No cons. Pros: Smoother shifting, easier to find neutral....Instead of modding the stock star, I bought a Cascade one ....worth the 35 bucks IMO. While your doing the shift star, might as well throw a pancake bearing and new idler gear bushing in there too. Cheap mods and worth the piece of mind IMO. Here ya go: http://www.farmandsandtoys.com/partdetail.asp?partid=69 Quote Link to comment Share on other sites More sharing options...
keeks707 Posted August 19, 2011 Author Report Share Posted August 19, 2011 Ma, all i see are good things about this mod!!! how hard is the install? anyone have a how to do it? Quote Link to comment Share on other sites More sharing options...
06specialedition Posted August 19, 2011 Report Share Posted August 19, 2011 Ma, all i see are good things about this mod!!! how hard is the install? anyone have a how to do it? Its really easy, there is just a screw holding it on. I just went off this bottom end walk through: http://bansheehq.com/forums/index.php?showtopic=140912 Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 20, 2011 Report Share Posted August 20, 2011 pro-s?- well, you don't have to push so hard on the shifter to cam it over to the next ger, which can be tiresome, so yah, it's good for shifting in that manner. do not confuse the mod with thinking that the trans will go into the next gear easier. it will not change the meshing at all, just gove you better controll. cons: well ther are 2 i can think of, but it only applies to a smaller amount of riders. first, many override trans do not work well with a modded shift star, because keeping the drum in place while in gear is more important, and bacl-load is more likely to move a shift-star-modded setup than a stock star setup. 2nd, if you ride circuit, or really rough, like woods, of=r something where you expect the sifter to get bumped often, and you want it to stay more solid. don't get me wrong, the mod will not make it shift on a whisper, but once you put your foot on th pedal, it is not going to be such an underttaking to get it to grind on over to jump into the next gear like a jack-rabbit, rather, you have more controll.. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted August 20, 2011 Report Share Posted August 20, 2011 pro-s?- well, you don't have to push so hard on the shifter to cam it over to the next ger, which can be tiresome, so yah, it's good for shifting in that manner. do not confuse the mod with thinking that the trans will go into the next gear easier. it will not change the meshing at all, just gove you better controll. cons: well ther are 2 i can think of, but it only applies to a smaller amount of riders. first, many override trans do not work well with a modded shift star, because keeping the drum in place while in gear is more important, and bacl-load is more likely to move a shift-star-modded setup than a stock star setup. 2nd, if you ride circuit, or really rough, like woods, of=r something where you expect the sifter to get bumped often, and you want it to stay more solid. don't get me wrong, the mod will not make it shift on a whisper, but once you put your foot on th pedal, it is not going to be such an underttaking to get it to grind on over to jump into the next gear like a jack-rabbit, rather, you have more controll.. There is ways to cut a star to make it easier on the up shifts and still keep it from jumping gears. Just post a pic of the star/drum you bought from me. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 20, 2011 Report Share Posted August 20, 2011 There is ways to cut a star to make it easier on the up shifts and still keep it from jumping gears. Just post a pic of the star/drum you bought from me. lol, yah, that is a purdy wave, i might do that today, if i can remember.... Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted August 20, 2011 Report Share Posted August 20, 2011 I shot s couple vids thatll help you get to and remove the shift star. Here they are. Quote Link to comment Share on other sites More sharing options...
camatv Posted August 20, 2011 Report Share Posted August 20, 2011 modded gear fine override dont use a modified gear. Quote Link to comment Share on other sites More sharing options...
