TeamRealtreeHD Posted July 23, 2010 Report Share Posted July 23, 2010 Will NGK LB05F plug caps work for the banshees? I am using NGK BP8ES plugs. I am reading that LB05E is for banshees. I don't know the difference between LB05E and LB05F.. The only difference is the last letter. I got LB05F plug caps. Can anyone tell me if these will work (LB05F)? Or do I need different LB05E? Maybe I'll just run the stockers. Seems NGK spark plug caps aren't common among the BHQ guys. Thanks Quote Link to comment Share on other sites More sharing options...
99bansheeworked Posted July 23, 2010 Report Share Posted July 23, 2010 why dont you use the stock one be8s or w.e Quote Link to comment Share on other sites More sharing options...
rb0804 Posted July 23, 2010 Report Share Posted July 23, 2010 E is for terminal nut F is Terminal stud. Either one will work. You will have to remove the screwed on tip with one. Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 23, 2010 Author Report Share Posted July 23, 2010 E is for terminal nut F is Terminal stud. Either one will work. You will have to remove the screwed on tip with one. You are right. I eventually figured it out. Thanks to Meat (BHQ Supporter and moderator) and Del at Gap Racing where I got them at. The caps I got from them are the kind that you have to remove the threaded tip and plug the plug cap right onto the threads on top of the plug. IMO, that is the way to go. It seems much more sturdy and dependable. Atleast I know they will work. I hope NGK plug caps are good. I hear good things about them. I guess we will find out. Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted July 24, 2010 Author Report Share Posted July 24, 2010 Anybody running these caps? Or should I go back to stockers? I paid 5 bucks apiece for them. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted July 24, 2010 Report Share Posted July 24, 2010 that's all i buy. that's what they carry behind the counter at sno-go shops, lol. just run them. ngk is a great brand. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted July 25, 2010 Report Share Posted July 25, 2010 NGK caps is all i use. Quote Link to comment Share on other sites More sharing options...
