J.J. Posted January 26, 2010 Report Share Posted January 26, 2010 I'm working in China, so decided to check-out the infamous radiator. Unfortunately, it will be a while before I can actually fit this thing to my bike or even compare it to the stocker. I took some photo's (I used my D90 seeing that some members don't like cellphone pics. lol) Shipped with EMS, packaging was ok, none of the fins were bent. Welds are not the tidiest, beads are inconsistent, but seem plenty strong. Lots of filler used on the hangers and tubes. Doesn't look like it will leak. This is the worst looking weld. The vendor states a 30% increase in capacity, not sure what capacity he refers to; volume or cooling capacity? The total volume to the top of the upper tank is 1 litre, not sure how much the stocker holds. If the 30% increase is in the coolant volume and not cooling capacity or core surface area, then it's not worth bragging about. The core is a double row core, btw. Quote Link to comment Share on other sites More sharing options...
J.J. Posted January 26, 2010 Author Report Share Posted January 26, 2010 My major concern is the cap, it feels a bit flimsy, but it looks like it should work fine. I'm hoping to exchange it with a stock cap, but not sure if a stocker will fit. I took some measurements of the filler neck if someone would like to check if the stock cap would fit. Outside diameter of the lock-ring - 43.10mm Inside diameter of the lock ring (and the cut-out for the locking tabs on the cap) - 37.9mm Inside diameter of the filler neck - 31.5mm Height, valve seat to the top of the filler neck - 16.00mm I also got the hoses, not much to say about them, look ok, will have to see how they fit on the bike. Feel free to ask for extra photo's or dimensions. Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted January 26, 2010 Report Share Posted January 26, 2010 http://bansheehq.com/forums/index.php?showtopic=125501 I think its the same one..... At least with pics.... Thanks J.J!!!! :-) Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 26, 2010 Report Share Posted January 26, 2010 Yea I think it is too. Only the review was done right. Thanks man. Your stock radiator cap should fit. It is just the standard import size cap. The should all be the same. Quote Link to comment Share on other sites More sharing options...
J.J. Posted January 27, 2010 Author Report Share Posted January 27, 2010 It's the same product as the other thread. E-Bay Quote Link to comment Share on other sites More sharing options...
BigMatt Posted January 27, 2010 Report Share Posted January 27, 2010 My major concern is the cap, it feels a bit flimsy, but it looks like it should work fine. I'm hoping to exchange it with a stock cap, but not sure if a stocker will fit. I took some measurements of the filler neck if someone would like to check if the stock cap would fit. Outside diameter of the lock-ring - 43.10mm Inside diameter of the lock ring (and the cut-out for the locking tabs on the cap) - 37.9mm Inside diameter of the filler neck - 31.5mm Height, valve seat to the top of the filler neck - 16.00mm I also got the hoses, not much to say about them, look ok, will have to see how they fit on the bike. Feel free to ask for extra photo's or dimensions. hey, buddy i tried the stock cap on this radiator it worked, but i have to tell you there is no difference between the to as far as quality goe's but the china sticks is pretty ugly. Quote Link to comment Share on other sites More sharing options...
J.J. Posted January 27, 2010 Author Report Share Posted January 27, 2010 hey, buddy i tried the stock cap on this radiator it worked, but i have to tell you there is no difference between the to as far as quality goe's but the china sticks is pretty ugly. thanks Matt, much appreciated! Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted January 27, 2010 Report Share Posted January 27, 2010 Just saw these on ebay last night for $99.95 now. I also saw boss atv radiators for $125. Thanks for the review, let us know how it holds up. Quote Link to comment Share on other sites More sharing options...
BigMatt Posted January 27, 2010 Report Share Posted January 27, 2010 I got one cant complain I also have a trail tech vector, I started out with a PWR radiator that came with the bike, good thing he gave me the stock one to, I soon shot off the trail and a branch went rate threw it, after I cried I threw on the stock one, it leaked so I bought this china one for $145.00 I thought it would just be a temp fix for now, but its held up for 4 months and the best part I added a billet impeller my temps a between 12 to 20 degrees cooler so vector says. and this was when air temps were about the same, the welds are nice on the unit and over all look to be well made, I recomend this to anyone with a budget. one thin to watch for is the overflow and the coolant line that goes off te head the fittings are not at the same height(like stock) do not cross these or all your coolant will run in your overfow. fitting by the radiator cap goes to your overflow(highest point) the other fitting that is on the other side and slightly lower goes to the coolant line off the head! hope this helps i can always send pic's Quote Link to comment Share on other sites More sharing options...
bigborebanshee Posted January 28, 2010 Report Share Posted January 28, 2010 Funny how these radiators got cheap all of the sudden...i would not doubt if Pro design and PWR have been outsourcing their radiators for years and still getting a premium! Im sure they will bring their prices down once they see sales slide. Quote Link to comment Share on other sites More sharing options...
BigMatt Posted January 28, 2010 Report Share Posted January 28, 2010 Funny how these radiators got cheap all of the sudden...i would not doubt if Pro design and PWR have been outsourcing their radiators for years and still getting a premium! Im sure they will bring their prices down once they see sales slide. I saw a guy on ebay selling a boss radiator now he could be lying but they look just like the chinese radiator? Quote Link to comment Share on other sites More sharing options...
87sheerips Posted February 5, 2010 Report Share Posted February 5, 2010 How long does this take to ship to the states? Quote Link to comment Share on other sites More sharing options...
BigMatt Posted February 6, 2010 Report Share Posted February 6, 2010 How long does this take to ship to the states? well when I bought this radiator it took only a week, and im in michigan, But up to two weeks ASI ships really fast for over seas I bought RC parts that have taken over 2 weeks so ASI is good for shipping plus they are easy to contact. and get back to you fast Quote Link to comment Share on other sites More sharing options...
