small bore pipes on big bore engine....
lt1bird
Wondering if anyone has used small bore pipes on a big bore engine? Im just wondering how it ran? Ran out of steam up top? lacked max power acorss the whole rpm range? maybe someone who actually has done this can chime in. small bore being stockish 350, big bore being around 500cc... guess im wondering how much hp is lost due to too small of pipes.
Thanks!
The small bore on anything bigger than a 10 mil Cub would probably hold too much heat. The BB should get rid of heat better; however I've ran both on my 10 mil Cub and didn't make any difference at the track. It ran leaner at part throttle with the BB pipes, so that probably negated any effect on the heat. On the dyno the SBs peaked about 400-600 rpm higher, but the max hp was about the same. THese results will vary depending on exhaust duration, of course. Mine is only about 192*. Neither pipe utilizes the potential hp of my engine.
Thats really cool info. Now the pipes you tested, were they drag pipes or basic pipes?
Thanks!
MIne were both OOF Shearers (drag pipes) out both sides. I ran back to back passes. 3.89@ 78-80 mph on both. MOtor was on alky, if that matters.
sb for more bottom bb for top I haven't run bb pipes but a 446 with sb drag port was like a dune port nice all around power
The opposite was true for mine on the dyno. Peak hp at about 9,000 rpms with BB and 9,600 rpms with SB. Just my experience on 1 particular motor.
all depends on how you want the motor to pull. i like more lower rpm hit BUT i also like a high revving engine. small motors like to REV bigger motors are more lower rpm's so the pipes are fitted to work on what they are intended. the 535 cheeta i have i use the big bore pipes it looses less hp as it heats up (dune racing) and will launch a hell of a lot harder when you load the shit out of the motor. that is bigger gearing heavier rider and lot more tire..
a lil 350 can rev and make power well into 11000 rpms the big bores will really fall off after 10000 i know on mine i use 7500-10500 rpm range ( its also powervalved) a 535 i would choose a big bore pipe and gear it up tire it up.
